Kyocera 2552
  • Ditchman
    • Feb 2011
    • 51
    Kyocera 2552
    Can anyone shed any light on it
    • 16395
    Re: Kyocera 2552
    Never heard of UTAX. From what I gather, they're putting their name on a Kyocera machine? In any event, it's probablly the chip. I'd probably just use Kyocera toner for for that machine.
      • 30255
      Re: Kyocera 2552
      Most likely RIDF sensor some-where on the toner
      Dont think it's anything you can do to fix
      Buy the correct toner
      There is probably a sim in engineering mode to change this but Kyocera will NEVER release the information to let you do it.
      To prevent dealers from doing what your doing.
        • 23008
        Re: Kyocera 2552
        On earlier machines you needed to set the destination (badge) for Utax, rather than Gestetner or Monroe or Copystar or Kyocera.
        On these same earlier machines destination was at U265
        Setting:
        Copystar 66
        Kyocera Mita 2
        Utax 11
        Olivetti 12
        No guarantees that this information is correct on recent machines.
        Keep in mind that you'll need to change print drivers. The encryption code for used for Kyocera is different than the other destinations. Many of the driver features will not be available is the destination does not match the manufacturer driver.
        • KYO_OEM
          • Aug 2011
          • 719
          Re: Kyocera 2552
          No way !!
          Change from U265 is not enough.
          You need other sub pwbs with SN from TA/ UTAX.
          e.g.
          Taskalfa 2552 SN starts with W35xxxxx for KDE systems, with VPNxxxx for Philcopy, R5R for Olivetti .......
          UTAX 2506ci SN starts with VFZ/ VFLxxxxx
          Depended to first 3 digits system knows exactly the sales company and you can`t use toner from other sales company.
          New sub pwbs you can`t order!
          By the way,
          UTAX is a trademark from TA Triumph-Adler. System sale only by dealers, no direct sale.
          TA Triumph-Adler, direct sale company + distribution, 100% Kyocera Group Company
            • 23008
            Re: Kyocera 2552
            Originally posted by KYO_OEM
            No way !!
            e.g.
            By the way,
            Good to know. Thanks KYO_OEM! =^..^=
            • kubajz27
              • 6
              Re: Kyocera 2552
              Hi, it is too long ago... We buy toner for Kyocera and try insert to Olivetti relabeled from KM-3035... Not possible - other gears
              I think it is in their business interest - not to allow it in different ways. Chip and their location, locks, teeth, gears ...
                Re: Kyocera 2552
                thanks but the subject was UTAX not Olivetti
                • Calliem
                  • Jul 2015
                  • 14
                  Re: Kyocera 2552
                  im thinking change u265 if possible and load some utax fw.
                    • 30255
                    Re: Kyocera 2552
                    KyoceraMita made machines for Olivetti at one time Genius
                    KyoceraMita also bought color machines from Konica at one time
