TA 4500i error 2201
  • Gab
    • Aug 2015
    • 671
    TA 4500i error 2201
    Because machine is at a distance before i go there i need some advice. This error is about drum motor . I will reset the machine first and then replace motor. Do i have to do or check something else?
  • KYO_OEM
    • Aug 2011
    • 719
    Re: TA 4500i error 2201
    Take a look for the drum.
    Have had several cases with blocked drum waste forwarding.
    After mounting from new drum, problem solved.
