CS3552 Magenta Developer unit
  • StratManDan
    • Nov 2018
    • 96
    Hi Guys,
    Has anyone experienced, while working on a CS 3552cidn, the gray, shaft lock button on Kyocera's Magenta Developer unit failing to stay pushed in? When this button is in it's out position, the mag roller is out of position, away from the drum, and toner will not show up on the prints. I, now, have run across 6 Kyocera Magenta Developer units, that have done this. None of the other developer units, k, cyan, or yellow, that I have seen, do this.
    As far as I know, there isn't a tech bulletin on this either.
  • FriendlyTech
    • Jan 2018
    • 30
    Re: CS3552 Magenta Developer unit
    I've had one break before, I can't remember which color it was though
    • StratManDan
      • Nov 2018
      • 96
      Thanks for the response. Just to reiterate, it seems odd that only the magenta developer units have this flaw. Weird. I'd be interested to know, if there's a way to fix this issue onsite.
      • Luther
        • May 2006
        • 682
        I have had it happen on cyan 3 or 4 times on early models, there were changes made to the lock in later developer units, to get it working with the broken lock i stick a piece of plastic between the lock and the cover to hold the gray lock in
        • StratManDan
          • Nov 2018
          • 96
          Thanks Luther,
          I've also thought of that, which I agree, would work. Having a suitable piece of plastic on hand to wedge in there, has been a shortfall of mine. The only other recourse is to simply order a new unit. I appreciate your input!
            • 23006
            One of our techs used the wooden shafts of hospital cotton swabs, and cut 4 or 5 "stakes" with a tapered end. He was happy with the results. =^..^=
            • StratManDan
              • Nov 2018
              • 96
              That's a good idea, blackcat!
              Those could be picked up at a pharmacy, I suppose. Where, exactly, on the developer unit, would he place it?
                • 23006
                The way I understand it, he jammed in these stakes around the edges of the gray button, then snipped off any sticking out. =^..^=
                • StratManDan
                  • Nov 2018
                  • 96
                  Sounds like a good plan! I will pick up some wooden q-tips asap! I really appreciate the input!
                  Thanks for all the input, guys!
                  • 20gaugeO/U
                    • 557
                    Cut two half inch pieces of your canned air straw off. Taper the end of the straws by crushing with pliers and slide both in. I use 2 (one on top of the other just for a little extra push. If it's close to the PM I leave the straw mod, if it's going to be a while and it's under warranty I'll order the dev and come back. Just had a black dev fail last week on a high volume 6052ci
                    • StratManDan
                      • Nov 2018
                      • 96
                      Thanks for the tip 20gauge!
                      • tmaged
                        Owner/Service Manager
                        • Oct 2008
                        • 1880
                        I've done a small plastic screw in there. It threads into both sides & you don't have to worry about it coming out.
                        Hope that helps !
                        -Tony
                        www.dtios.com
                        Become a fan on Facebook
                        • StratManDan
                          • Nov 2018
                          • 96
                          Another good tip! Thanks!
