Help with printer km3530
  • randyprinter
    • Sep 2020
    • 11
    I recently installed the maintenance kit and replaced drum, developer, fuser and rollers about six months ago. Everything was working smooth until now. Please see picture I don't know what it could be. 123_1(1).jpg123_1(1).jpg
    Re: Help with printer km3530
    Originally posted by randyprinter
    I recently installed the maintenance kit and replaced drum, developer, fuser and rollers about six months ago. Everything was working smooth until now. Please see picture I don't know what it could be. [ATTACH=CONFIG]46805[/ATTACH][ATTACH=CONFIG]46805[/ATTACH]
    is the print in the defect area rubbing off? that would be the fuser.
    • randyprinter
      • Sep 2020
      • 11
      Some times it smudge. After 4-6 pages it comes out okay.
        • 29373
        Stop the copy before it enters the fuser, if image is ok then it's the fuser. If it's before check the DEV unit
        • randyprinter
          • Sep 2020
          • 11
          I will try that right away. Is there an easy way to stop it before it reaches the fuser? or do I just pull out the plug?
            open the front/top door
            • randyprinter
              • Sep 2020
              • 11
              I thought there was a kill switch. Sorry.
              • Scottb
                • Apr 2013
                • 303
                does that model have the green pressure buttons for the fuser if i remember right like the fs3040 that may be your issue
                • randyprinter
                  • Sep 2020
                  • 11
                  Thank you for the reply if it is the issue how do you recommend I resolve it if there is a green button
                    if i not mistaken those are for envelope mode.. make sure they are both in the same position
                      • 29373
                      There is NO envelope mode fuser pressure is fixed!
                      No Falcon machine has adjustable fixing pressure
                        • 22929
                        It looks like fixing to me. What sort of media is this? What media type setting? Is the telfon coating intact on the heat roller? =^..^=
                          said the same thing brother...
