TA 3050 3550ci Fuser Belt (UFR) from Katun
  • Doug James
    • Jan 2012
    • 935
    [Misc] TA 3050 3550ci Fuser Belt (UFR) from Katun
    Has anyone tried to use the Fuser Belt from Katun. Does it work on the Higher speed machines as you can get these elsewhere that work on them all. Hoping to get some feed back Thanks so much !!!
    • 16391
    Re: TA 3050 3550ci Fuser Belt (UFR) from Katun
    I have not used this particular item from Katan. However, Katun is one of the leaders in aftermarket parts and supplies and I've had a lot of success with them over the past 20-years.
    My approach to using aftermarket parts & supplies is to always test it out thoroughly in-shop before ever using them in a customer's machine. Make sure if a fuser is rated for 300k that it actually lasts that long or at least close to it. That way you can have piece of mind when you do put it in a customer's machine. I would never use my customer's machine as a test vehicle for an item that I know nothing about.
    Katun has been in business for 40-years with $70-million in annual sales. They must be doing something right.
    My -2 cents.
      never liked the parts from katun... early days even their toner sucked.
      • craigster
        • Apr 2016
        • 201
        That fuser was not made to rebuild, life would suck if you tried. Bite the bullet and order a new one.
          • 16391
          This is true. I've never even attempted to rebuild one of these. It's looks like a real bitch of a process if I would have wanted to.
          • Doug James
            • Jan 2012
            • 935
            My -2 cents.
            Sure appreciate your 2 cents... I am the same way with them, a big fan...
            • Doug James
              • Jan 2012
              • 935
              True Story...
                • 16391
                OEM's preach using ONLY OEM parts and supplies. It is drilled in the heads of Authorized dealers & technicians. When I was a new tech I was indoctrinated into believing that all aftermarket parts and supplies were garbage. And I believed it.
                There's a reason that OEM's preach this philosophy. Why? Because they make more money on parts & supplies than they do selling actual machines. Of course OEM's don't want anyone buying after-market parts and supplies.
                It was years later after I went into business myself and actually experimented with aftermarkets parts and supplies that I learned the truth.
                Think about it.
                Ever talked to a GM or Ford mechanic? Many will tell you that aftermarket parts are crap. That's not true either.
                In the aftermarket world, there are good and the bad.
                I prefer to do my own research and take the guess work out of it.
                Because there are many aftermarket supplies that are crap, it's sullied the reputation of the aftermarket world in general. A tech will decide to try an aftermarket part or supply for the first time and it doesn't work and then they're convinced that it's all crap. I call this CONFIRMATION BIAS.
                • charge leak
                  • Mar 2020
                  • 15
                  I have rebuilt both fusers with Katun belts, takes about 1.5 to 2 hrs, I haven't had a problem with any rebuild yet.
                  • Doug James
                    • Jan 2012
                    • 935
                    Appreciate ya !! I have rebuilt a few and had problems with one but I think it was more my fault. Katun has a video of the rebuild and is great !!!
                    Kyocera Mita Taskalfa 3050 CI-series Fuser Belt Installation Instructions Video - YouTube
                      • 16391
                      Thanks for sharing. I've got to try it.
                      • jmaister
                        certified scrub
                        • Aug 2010
                        • 755
                        Less than 50k you are gonna get out of rebuild fuser for these.
                        Kyocera coulntd get their fuser alignment right from factory, bearing always fail prematurely vs claimed.
                        The process of rebuilding will change the stress balance on the rollers.
                        If you are in the bind, as we were, but you are starting a vicious cycle...your boss will find out you can, and soon he will ask if you rebuild others. And then you will find you will have less time for more important clients, and eventually, cut into your personal time.
                        Idling colour developers are not healthy developers.
                        • bcopier2815
                          • Oct 2015
                          • 42
                          So they work in the faster 4550's?
                          asking for a friend
                            • 23008
                            When VoyagerE's were the rage, and they were coming out with fuser updates every week, I was saving the cores and swapping around components to rebuild them, at least to get to the PM kit. It took 2 hours and (3) fusers to make (1) usable one ... with a lot of practice. There were (9) items to watch on the VoyagerE fuser:
                            Exit guide front (warp)
                            Exit guide rear (warp or cracks by the return spring)
                            Teflon coated inlet guide (cracks)
                            Belt separation guide (surface damage)
                            Heat belt (coating)
                            Foam roller shafts and bearing wear
                            Front fuser cover (broken latches)
                            Worn thermostats
                            I haven't had the pleasure of rebuilding an Alphard fuser. =^..^=
                            • Doug James
                              • Jan 2012
                              • 935
                              asking for a friend
                              lol... Tell your friend that I personally didn't have success with 4550 although I have had success with 3550 and lower. Hard to know if technician error (me) or not...
