Kyocera FS-1135 mfp - Can't scan to folder
    • 30469
    #16
    Re: Kyocera FS-1135 mfp - Can't scan to folder
      • 16465
      #17
      Thanks for sharing, dude. I think I'm gonna give that a try.
      • JR2ALTA
        • Feb 2010
        • 2033
        #18
        Good morning, Billy. The fs-1135 machine does not support smb v2 or scan to email with tls 1.2, firmware will not even fix it. The newer m2535dn does support smb v2, they are about 4 years old now but you can pu some lightly used on the cheap, or have their IT setup ftp.
        8 years old believe it or not.
        • copiertec
          • Jan 2016
          • 2211
          #19
          Wow, time sure flies!
          • dobo34
            • Jun 2025
            • 1
            #20
            I have an FS-1135MFP and found tha last Firmware in the web. In the changelog stands with the latest version support for SMB v2 and v3 was added.
            I have installed it and it works with Scan to folder to my synology nas with only smb v2 and smb v3 allowed.
            If now also TLS 1.2 is supported I haven't tested.
            Here I have uploaded it: https://limewire.com/d/CIXoz#PZ42zRAK8k
            You can try it. For me it works now.😊
            • Black Cloud
              • 174
              #21
              All is not lost. It can still scan to usb memory stick. Scan to FTP utility should also not work because it is non encrypted and all firewalls block it.
              Net+ PDI+ @Remote
