Kyocra 3252ci line on drum
Re: Kyocra 3252ci line on drum
I see a lot of these machines if you fitted oem complete new drum and dev units I can't see what else cause that problem changing paper to a4r isn't fixing problem I don't know any Kyocera engineers that would do that.Regards Mark
https://copierservices.simdif.comComment
Regards Mark
so true.. you are inviting a case for arcing to the drum.Comment
Post a sample print.
Don't know this Kyo is it a mono component machine.
In the photo of the drum the one band looks polished off.
Could that be a raised mag brush due to damage or contamination on the mag roller.WhateverComment
The color machines are all dual component. Only the older monochrome MFPs and the monochrome printers are still monocomponent.If you'd like a serious answer to your request:
Problem solved. When installing new drums and developer units Please guys only fully insert the units by pushing the units in from the connector end of the units Do no push the units with the release lever section as the units may not be inserted straight hence the reason for the marks on my drum.
Thanks guys for all you advise.Comment
The rule of thumb for copiers is: "If it don't fit, don't force it."Adversity temporarily visits a strong man but stays with the weak for a lifetime.Comment
Thanks guys for all you advise.A tree is known by its fruit, a man by his deeds. A good deed is never lost, he who sows courtesy, reaps friendship, and he who plants kindness gathers love.
Blessed are they who can laugh at themselves, for they shall never cease to be amused.Comment
Your Dv has an issue.. see the image.. DV mag sleeve gone bad in the edge. it will affect the drum with arching .. Drum coating wiped of exactly opposite to this location. check it.Comment
Never had any problems when fitting these parts but I think it's always best to fit new oem parts first time.
Well done Fault sorted.Regards Mark
trying to find cure. transfer belt clean drive breaks. eatting drums and dv. set to koyoceera no answer yetComment
Change the drum and K dev unit and your problem will be fixed. Its probably the dev unit that caused the problem.Comment
