taskalfa 5500i
  • Gab
    • Aug 2015
    • 676
    taskalfa 5500i
    error F000 try to enter service mode typing 10871087 (|to execute some programms) but machine doesn't enters me into service mode . What's the problem?
    • 16486
    Re: taskalfa 5500i
    Try changing memory. If that doesn't work:
    F000: Communication error between main PWB and operation PWB
    Turn the main power switch off/on to restart the machine. If the error is not resolved, replace main PWB
    Replace the operation PWB and check for correct operation.
    • JR2ALTA
      • Feb 2010
      • 2033
      Re: taskalfa 5500i
      try to flash it
      • copier tech
        • 8202
        Re: taskalfa 5500i
        ​Try updating the firmware with the latest version.
        • Gab
          • Aug 2015
          • 676
          Re: taskalfa 5500i
          can i use memory from an other similar machine?
          • Gab
            • Aug 2015
            • 676
            Re: taskalfa 5500i
            Because i tried to upgrade firmaware but machine desn't accepted it i read thata i must use main usb not the one on panel . Where is it?
              • 30485
              Re: taskalfa 5500i
              open the front door than try
              • ntbann
                • Jan 2012
                • 631
                Re: taskalfa 5500i
                The main usb port is located on the controller at the back of machine.
                • ntbann
                  • Jan 2012
                  • 631
                  Re: taskalfa 5500i
                  You might have to do emergency firmware.
                  • KYO_OEM
                    • Aug 2011
                    • 727
                    Re: taskalfa 5500i
                    system won`t accept any USB key, no full start up procedure finished and finally no upgrade possible.
                    If system stucks in "Welcome", upgrade possible but if F000 is coming up after a while, it can`t work.
                    I tried to duplicate some possibilities.
                    See enclosed picture.
                    • Gab
                      • Aug 2015
                      • 676
                      Re: taskalfa 5500i
                      One colleague told me that i can not use dimms from other Kyocera KM 4035 machine. In that case i have to replace the whole print controller. Is that correct ? DO i need new dimms?
                      • Gab
                        • Aug 2015
                        • 676
                        Re: taskalfa 5500i
                        Originally posted by JR2ALTA
                        try to flash it
                        what do you mean by flafh it?
                        • makeacopy100
                          • Oct 2019
                          • 24
                          Re: taskalfa 5500i
                          i believe its a problem of main formatter board
                          try to clear memory if possible
                          follow the update instructions from manual and dont plug USB under the front panel
                          i am also dealing with the same model but the fault is something else
                          • KYO_OEM
                            • Aug 2011
                            • 727
                            Re: taskalfa 5500i
                            system needs HDD and 1 GB ASIC memory for communication between main board and operation panel.
                            In most cases, our technicians exchanged HDD and systems worked well again.
                            You can use used HDD and/ or 1GB memory dimm from other system.
                            In normal case system will start FW upgrade with other HDD mounted..
                            • toddanderson
                              • Dec 2005
                              • 238
                              Re: taskalfa 5500i
                              KYO, is this image you attached only for zero machine ? or is it relevant to all the other series 1,2,3 ?
                              thank you
                              [ATTACH=CONFIG]47136[/ATTACH]
