km 8030 printing problem
  • fitsy.13
    senior tech
    • 64
    hi has anyone come across a problem the the print board on this model i have a customer that sends pdf files on direct print but the machine seems to have a fit and just sits there i have downloaded all the latest drivers and firmware the customer is using jde and as400 is this the problem
  • kyoceradude
    The Great Gazoo
    • Aug 2006
    • 442
    When you say direct print, do you meen from the KM-Wide utility? If so you can not send pdf's thru the utility. The file needs to be opened with Adobe. Correct me if I'm wrong on that.
    NEVER MIND WRONG MODEL... DUH!!!!
    My mission here on Earth is to help all you Dum-Dums!
      • 23010
      First thing that I would do is set the print driver emulation to PCL, instead on KPDL. This has solved lots of problems for me regarding large pdf files, and print board lockups.
      • fitsy.13
        senior tech
        • 64
        thanks anyway i have sorted it with km i needed to put it on ibm for the system here
