An Older Ecosys FS 9130 Shrinking print on left side....
  • Doug James
    • Jan 2012
    • 935
    [CQ] An Older Ecosys FS 9130 Shrinking print on left side....
    I attached an example of this FS 9130 print. Printed LEF It's an older machine so I wanted to double check the problem. I am Thinking the registration clutch. Appreciate any responses... THANKS !!!
    • 22698
    Re: An Older Ecosys FS 9130 Shrinking print on left side....
    This is a FalconIII. And if that compression is ~36mm from the trailing edge, I would check to see if the transfer roller springs and bushings are intact.
    If you're getting jam J40, J41, J42, J46, J81, J87 accordianned in the fuser, I'd take a closed look at the fuser exit guide (if you can get it: 302GR25371). It was very common for endusers to slam the hell out of the door, shattering the stops off the end of the exit guide mounted to the door.
    You might also have seized fuser bearings. =^..^=
    • Doug James
      • Jan 2012
      • 935
      Thanks so much !!!
      • taskalfaman
        • Nov 2009
        • 137
        [ATTACH=CONFIG]47134[/ATTACH]
        Hi,
        change the tr-710, most likely one spring out of position or plastic broken.
        have fun
