Kyocera 3501i uneven density on prints
  • rapo_tech
    • Feb 2019
    • 114
    Hello
    I swapped MK kit on this machine 1,5 months ago. Run necessary maintenance modes and updated firmware to v.05.07.0010_(2016-06-27)
    Everthing was ok.
    But now there are faded lines on black.
    I added samples:
    PG grey scale - PG GRAY SCALE.pdf | DocDroid
    halftones calibration page - halftones calibration page.pdf | DocDroid
    a copy made when scanner cover was open - scanned copy of open lid.pdf | DocDroid
    All have same faded white lines in them.
    Calibration page and the copy is printed Long Edge First.
    Toner and all parts are OEM.
    Ok first i removed developer and shaked the hell out of it nothing changed...
    Ok so i executed U910.
    Then executed U412 uneven density
    The ON/OFF config was set to ON.
    Then I tried U410, it printed out samples but did not recognize samples when scanned them and gave me error S001. Propably due poor quality.
    Any ideas where to go next?
    Re: Kyocera 3501i uneven density on prints
    Originally posted by rapo_tech
    Hello
    Everthing was ok.
    I added samples:
    You replaced 600k Maintenance kit?
    Kit Includes:
    (1) Drum Unit [302N993030]
    (1) Developer Unit [302LH93034]
    (1) Fuser Unit [302LH93102]
    (2) Top Filter [302N433010]
    (2) Left Side Filter [302LC33370]
    (1) Belt Assembly SP [302LF94060]
    (1) Disposal Unit Assembly [302N794020]
    (2) Drum Duct Seal
    You need to run the following depending on what you replaced:
    Drum: U119, 464, 412, 410
    DV: U464, 410
    PCR: 930
    Transfer Belt: 127, 464, 410
    The 600k kit does not include the transfer roller. You may want to check that.
    • rapo_tech
      • Feb 2019
      • 114
      Kit Includes:
      (2) Drum Duct Seal
      DV: U464, 410
      PCR: 930
      Thats the thing that got in my mind also. Cause i measured the black lines on printout - they were ~45mm apart and the manual indicates that transfer roller repetitive defect gauge is 44mm.
        Yep changed all the MK kit parts and run all those modes.
        I think you have your answer.
        • rapo_tech
          • Feb 2019
          • 114
          Ok i definatly check transfer roller.
          But any idea where those drum duct seals supposed to go?
            Nope and I see nothing in the service manual about them. Someone else will have to help you out there.
            • rapo_tech
              • Feb 2019
              • 114
                • 22981
                I think Billy means the Second Transfer Roller, not the Primary Transfer Roller. You know, the one on the outer door? =^..^=
                • rapo_tech
                  • Feb 2019
                  • 114
                  Well.. yes i was looking also the secondary transfer roller, but i did not find it
                  And i did not find it in manual... So i was assuming that this machine has none... and therefore i was wondering whats the point of transfer belt here :P
                  The belt is on the outer door.
                    • 22981
                    You are correct, the monochrome MFP uses a transfer belt assembly with a transfer roller in the center,
                    and the color MFP uses a second transfer roller only.
                    The way Kyocera names their machines it's easy to confuse 3501i with 3051ci at a glance.
                    • rapo_tech
                      • Feb 2019
                      • 114
                      So today i updated firmware to latest v.07.09.0060_(2020-03-17)
                      And tried to set U464 toner thickness value to initial setting 750...
                      But still nothing changed.
                      I noticed that a pin in connector for the side door was a little bit different than others.
                      125209276_427952881943403_3303924130841155553_n.jpg125200233_996229897554055_6616908834240204498_n.jpg
                      It is like 1mm more outside than others... Tried to push it back in, but it does not move much.
                      Maybe thats the bad boy here??
                      • Luther
                        • May 2006
                        • 682
                        did you try cleaning the laser glass ?
                          • 22981
                          Probably not. Often the manufacturer of those modular connectors positions one of the pins longer than the others. If you look closely I think you'll see that they're the same. I've noticed it, just don't know why. =^..^=
                          • Blizzoo
                            • Aug 2013
                            • 604
                            Would that be a GND Pin?
                              How about posting a picture of some test prints so we can see the problem?
