Olivetti 4500i black copies
  • deltic
    • Feb 2019
    • 4
    Hi all i changed a toner in machine it was working fine before and tested all good after 50 copies the pages went black all over with the image there even the leading edge is solid black so i replaced the charge roller checked dev unit 300k copies got it going next day same thing i did notice the dev unit running on after the machine stopped copying its supplying toner ok change dev unit with a used one lasted a day any ideas thanks when the dev unit was running on it wasnt adding toner
  • copiertec
    • Jan 2016
    • 2205
    Re: Olivetti 4500i black copies
    I'm not sure I follow you but from what I understand you have swapped developing units (300k) and still have black copies. Have you run internal prints? I am assuming OEM toner? I would make sure your process unit is grounded by using grease on the drum shaft. Sounds like an electrical issue to me. Also, TA-5500i
    • deltic
      • Feb 2019
      • 4
      Thanks i am using oem toner i will check drum shaft it was a used dev unit to see if problem went away no joy the machine was fine till i put toner in would a bad ground on drum cause the dev unit to keep running on after it stops copying thanks again
        • 23007
        Any time the machine makes solid black copies & prints, the developing unit will struggle to tone up the developer ("running on")
        Fix the black copies and the running on will stop. =^..^=
