FS3640MFP doc feeder quits after 5-10 minutes
  • big mike
    • Sep 2012
    • 155
    [Misc] FS3640MFP doc feeder quits after 5-10 minutes
    My 3640 document feeder will work for 5-10 minutes and then quit, like it looses power.
    When I turn it on it works fine, later it's dead. I can print and copy from the glass. A different feeder does the same thing. No errors show up in the event log. Any ideas?
    • 30567
    Re: FS3640MFP doc feeder quits after 5-10 minutes
    Check the pins for the Adf connection
    or bad wiring harness
    • big mike
      • Sep 2012
      • 155
      I did and reconnected it at the main pwb. It's working properly now. Thanks!
