TA 3500 Paper Curling in exit tray and bunching up...
  • Doug James
    • Jan 2012
    • 935
    [Misc] TA 3500 Paper Curling in exit tray and bunching up...
    Hello, Occasionally the paper is curling in exit tray and bunching up. (I have been a tech for 25 or so years) I told the customer that is the paper that has collected moisture over time. I said to maby change the paper would help. They tried Hammermill and it does the same thing (Also, The copier has a new fuser). Is there anything I can do to help this customer. I just assume that they are in a high humidity area. Thanks so much for any help !!
    • 16456
    Re: TA 3500 Paper Curling in exit tray and bunching up...
    Did you verify that the customer opened a fresh ream of paper or did they just tell you this? It's not that I don't trust the customer...I don't trust anyone.
    • 20gaugeO/U
      • 557
      Change the orientation. Gonna assume it's 8.5x11 LEF, so change it to SEF. If that's the paper they want to run sometimes that's all you can do
      • Doug James
        • Jan 2012
        • 935
        I will give that a shot THANKS !!!
        • Doug James
          • Jan 2012
          • 935
          I hear ya on the trust factor
          • sparkycivic
            • Apr 2017
            • 348
            Perhaps try to adjust the paper weights for plain to the lightest value which still still yield reliable fusing. this will apply the least amount of heat and therefore less curling of moist paper...
            Doing the opposite might also work by driving the moisture completely out.
            • Doug James
              • Jan 2012
              • 935
              That's a Great idea. Heading there on Monday. I will post my results THANKS !!!
                • 30430
                Did you turn on the paper tray heaters?
                • tsbservice
                  Field tech
                  • 8040
                  Valuable advices received. I would only add not knowing Kyo but in KonMin you can actually adjust fuser temperature helps in preventing paper curl.
                  • Doug James
                    • Jan 2012
                    • 935
                    I didn't think it has paper tray heaters. I will have to check. Thanks so much !!!
                      • 23010
                      The same applies to Kyocera. The fusing temperature for Alphard toner is quite low, so you've got some wiggle room. The best way to do it is not in simulation, it's to change the temp value (normal1, normal2, normal3, thick1, etc.) for Plain media type.
                      • Doug James
                        • Jan 2012
                        • 935
                        Thanks so much !!!
                        • Tonerkiller
                          • Oct 2012
                          • 669
                          Make sure all the filters are clean.
