KYOCERA FK-8550
  • EDSNOW
    • 187
    KYOCERA FK-8550
    Just wanted to ask if anyone has had to replace one of these fusers due to noise and also a buildup of rust colored powder within the fuser.
    I suspect bushings wearing out.
    I have had about three on various 52/53 series machines both color and mono products.
    I also have had to change a couple of these fusers that either give a error code and also in the case of some color machines have caused the toner covers to open.
    Just putting it out there to see if others have had any of these issues.
    Up to this point doing RMA replacements has helped without costing too much other than freight.
    I appreciate any responses.
    thanks
    Ed
    • 23010
    Re: KYOCERA FK-8550
    Yes, all of those things.
    https://www.copytechnet.com/forums/k...ion.html#post1
    • EDSNOW
      • 187
      Re: KYOCERA FK-8550
      Appreciate the response.
      Otherwise for the most part these products work OK.
      Regards
      Ed
      • KYO_OEM
        • Aug 2011
        • 725
        Re: KYOCERA FK-8550
        look for confidential information about modified FK connectors from new Iris series (coming soon) regarding FK errors on Iris 1 + 2 (Seems to be well known on KYO side....)
        Also maybe the FK unit wasn`t the reason
        Look for both other bulletins
        • EDSNOW
          • 187
          Re: KYOCERA FK-8550
          Appreciate the information.
          I was aware of foreign material getting into connectors. (Bulletins)
          The rust colored material is what I have encountered in most of my units.
          Ed
            • 906
            Re: KYOCERA FK-8550
            Are Kyo rep suggested putting silent mode ON to extend the life of the fusers .
