kyocera 4050 scan to thumbdrive
  • Tom
    • 344
    Hey all, I had a customer asking if they could use the thumbdrive port to scan documents to. I said sure, they all do it, but when I tried to show her I couldn't figure it out. After doing some research, it appears that older series may only print from thumbdrive, but not scan. To be honest I've never had a customer on one of those ask to use it so I wasn't sure, I know all the newer ones can. Their scan to email is working fine, but she wanted to use the thumbdrive option also. Is that possible?
    • 16416
    Re: kyocera 4050 scan to thumbdrive
    I think it's the other way around. On the older machines you can scan to USB but can't print from.
    Check to see if USB is blocked. Make sure USB is firmly plugged in. Is the USB device recognized?
    • Tom
      • 344
      When I was looking up information on it, it said it could print from usb. I didn't see anything about scanning to it though. I know the other models do both, they have a 6525 in a different room that will do both. They may have to walk over there and use that one if they want thumbdrive scanning cause when you put it in nothing pops up but if you go into different areas it shows that it's there, just no way to send to it that I can see.
        • 16416
        This is a pretty old model. I've worked a couple but never had to deal with USB scan. I was looking for an operator's manual for it but no luck.
        • Tom
          • 344
          Just to verify, when I say USB I'm talking about thumbdrive before anyone skims over it and says it won't scan usb. It is networked for regular scanning.
          • Scott
            • 196
            The older units you can print but no scan
              • 23009
              I never noticed that before. The brochure confirms it. No scan to USB. =^..^=
              • bronco31
                • Aug 2009
                • 174
                you cant scan over USB, only over the IP network
