Kyocera 3551ci cyan bands
    Re: Kyocera 3551ci cyan bands
    Very interesting. I learn something new on here every day. I've seen bands similar to these when the DV spacers get worn. But I can't say that I've seen the curved aspect or I just didn't notice. I'll be sure to check if the DV bearings are seizing.
    I've seen this on all units that are dual component dev units.
    The build up is classic of: dev dumping.. bushings.. space collars worn.
    • Luther
      • May 2006
      • 682
      #17
      It's the developer for sure, you may try a dv refresh and it may clean up, but eventually you're going to have to replace it
        • 30303
        #18
        OEM toner is this machine?
        • WLIT
          • Jan 2020
          • 40
          #19
          I would try developer refresh once or twice. Have seen this in mfps that don't do much color printing. If not OEM toner especially.
            • 16416
            #20
            Just a quick follow up:
            I went back to this account last week and whatever was causing the cyan bands, the problem is now gone. I ran off several test prints on arrival and no signs of the problem. I then pulled out the cyan DV just to make sure there was no problem with the DV roller locking up or being hard to turn. No problem found. Hopefully the problem doesn't come back.
              • 23009
              #21
              Agree. On machines with extremely low color usage a developer refresh (or two) can bring back the density. BUT ... if it's not improved, do not run it a third or fourth time consecutively. I've seen it go from slightly undertoned to massively overtoned on the third or fourth refresh, guaranteeing the need to change out the developing unit. =^..^=
              • Samanator
                • Sep 2017
                • 579
                #22
                I don't know if this will help but in every Kyocera manual there is a page in the Appendix called 'Repetitive defects gauge'. It's different for every model. I have attached the one for the xxx1ci model.
