Kyocera 3551ci cyan bands
    I stopped by a customer's office to drop off toner on Friday. They were about to close but I did a quick check of the machine and noticed cyan bands. The bands get progressively lighter from the top of the page to the bottom until they fade away. I measured the repetitive bands : 1 9/16. It's kind of difficult to get a precise measurement because part of the bands fade from the first to second band and the circumference of the PCR is 1 1/2 and that's only 1/16in. difference from the mag roller.
    Thoughts? See image below.
    Edit: The page count on the cyan DV & PCR is 94k.
    doc00000820210130194242.pdf
  • JR2ALTA
    • Feb 2010
    • 2028
    Re: Kyocera 3551ci cyan bands
    Given the curve and distance I would guess the mag roller and to replace the dev unit.
      • 22929
      +1
      Did you notice the spots from the cyan primary charge roller?
        I'd feel much better if you guys told me it was the PCR. Can you lie to me?
        Thanks for the advice guys.
          • 22929
          That wouldn't account for the curve to the line. Sorry. =^..^=
          • JR2ALTA
            • Feb 2010
            • 2028
            doubt it. you could have swapped them to be sure, tho.
              do you want the truth and a way to fix it?
              or do you wants lies and a warm fuzzy feeling?
              mag roller my dude
                +1
                First off, I believe both of you that it's the mag roller. But would you like educate me on you line of thinking? I'd appreciate it.
                Both the mag. roller and the pcr are round rollers. How can you determine that it's the mag. roller and not the PCR from looking at the curve of the cyan band? I need to know these things.
                Edit: I didn't notice the spots from the PCR until you just pointed it out.
                  mag roller my dude
                  LOL
                  I was joking.
                    because of the TYPE of defect
                    are you measuring from beginning of band *darker lead edge* to the same
                    or darker to fade?
                      or darker to fade?
                      Phil,
                      I measuring from the beginning of the band - darker lead edge. Yes, from darker lead edge from the 1st band to the same point on the 2nd band.
                      • JR2ALTA
                        • Feb 2010
                        • 2028
                        Repeating drum defects (not talking about blade streaks) tend to be cleaner and sharper. The curved smudgey blobs appear to be developer built up in a cruder manner.
                          That makes sense. Thank you.
                            • 22929
                            I've seen the curved bands crossfeed on Toshiba 2550C when the developer bearings are seizing. I think you'll find that the cyan developing unit is difficult to turn. The developing cylinder counter-rotates against the drum, so the interval does not directly reflect the diameter of the developing cylinder.
                            I would not recommend taking apart the Kyocera developing unit. I always end up with a pile of pieces that cannot be re-assembled. =^..^=
                              Very interesting. I learn something new on here every day. I've seen bands similar to these when the DV spacers get worn. But I can't say that I've seen the curved aspect or I just didn't notice. I'll be sure to check if the DV bearings are seizing.
