Mita FS 3140
  • Hoosierdaddy
    • Oct 2016
    • 181
    Mita FS 3140
    What is the procedure to Init. the Developer Unit to get the toner into the DV Hopper I know how to get into the service mode, but I do not see a description for that mode. Plz HELP
    Thanks Hoosierdaddy
  • copier tech
    • 8132
    Re: Mita FS 3140
    Thanks Hoosierdaddy
    Do you have the service manual?
    You get a sheet with the new DV showing what U code to use.
      • 22999
      Re: Mita FS 3140
      That piece of A4 size paper in the box should help. =^..^=
      • WLIT
        • Jan 2020
        • 40
        Re: Mita FS 3140
        Not in Service Mode. First make sure you have plenty of toner in the toner cartridge. Under function menu look for service there. Should be an item like "developer". Choose it and hit OK. Turn off mfp and restart. It will run and add toner until satisfied which may take up to 5 minutes.
        • JR2ALTA
          • Feb 2010
          • 2030
          Re: Mita FS 3140
          Yep, perfect. I swear I've seen some go 10 minutes.
          • copier tech
            • 8132
            Re: Mita FS 3140
            Performing toner install.pdf
