ECOSYS M6026cdn ADF duplex scan constantly jams on second side
  • richtoy
    • Feb 2021
    • 1
    [Jamming] ECOSYS M6026cdn ADF duplex scan constantly jams on second side
    Hi,
    I have a ECOSYS M6026cdn which will scan multiple pages single sided from the ADF without issue.
    However, requesting duplex scan results in a jam as the paper is returned from the switchback tray.
    It looks as if the paper is not being fed squarely by the rollers.
    Is there a recommended way to clean the switchback pulley and roller?
    The machine has only had light home use.
    Can anyone supply the latest firmware for this device?
    Thanks!
    • 22994
    Re: ECOSYS M6026cdn ADF duplex scan constantly jams on second side
    It will take some disassembly to get to them ... but I would use an orange oil based cleaner on those rollers. I doubt very much that you could accumulate much wear on a home-use machine.
    Before you do though ... open the top cover. Insert a heavy mylar report cover 8 1/2" x 11" into the paper path toward the slit glass, and roll it through. You might get a nice surprise, like a small scrap of paper blocking the duplex path, in a place you cannot see. This has worked for me in a number of situations where the paper path is mostly inaccessible.
    Cardstock would also work if you can't find a report cover. =^..^=
