Mita FS 3140
  • Hoosierdaddy
    • Oct 2016
    • 182
    Mita FS 3140
    What is the procedure that has to be done when the dv unit is replaced? There were no intructions in the box. Thanks in advance
    Hoosierdaddy
  • Ropariva
    • 680
    Re: Mita FS 3140
    Enter Service Setting. Select New Developer. Press Start, Yes.
    Turn off and fit new dev unit. Turn on, it will replenish toner for ten min or so. You may need a new toner cartridge.
    • copier tech
      • 8174
      Re: Mita FS 3140
      Hoosierdaddy
      Read the service manual maybe?
      • Hoosierdaddy
        • Oct 2016
        • 182
        Re: Mita FS 3140
        Could you provide me the Service manual? Im just a guy trying to stay in business. Independent techs are disappearing. If i had the manual I wouldnt be asking these basic questions. Its a old machine im trying to keep going for a customer.
        • Hoosierdaddy
          • Oct 2016
          • 182
          Re: Mita FS 3140
          Is Service setting the same as service mode? If so i entered that mode and didnt see that under any of the descriptions. I scrolled thru the whole menu.
          Thx for any further help
          Hoosierdaddy
          • copier tech
            • 8174
            Re: Mita FS 3140
            Here's the page you need.
            New Developer.pdf
            • Hoosierdaddy
              • Oct 2016
              • 182
              Re: Mita FS 3140
              [ATTACH]48226[/ATTACH]
              Thank You for the help. I appreciate it
              Hoosierdaddy
