5002i incoming fax tray switching..
  • bronco31
    • Aug 2009
    • 174
    Tray 1 and 2 both normal Letter ... incoming faxes over the weekend uses all tray 1 paper.. and doesnt ATS to tray 2... (but does ATS for a copy or print job)...
    customer is hurt and offended
  • nathicana
    • Aug 2008
    • 335
    Re: 5002i incoming fax tray switching..
    Check to make sure both trays are set to auto paper size. Kyoceras will not use a tray for fax reception if it has been manually set to a size.
      • 30291
      You can always set fax to scan to email or folder
        • 23009
        My first inclination was the Auto size detection ... but the newer Kyoceras allow you to "group" paper trays that you want to auto paper switch. You can find it in the Command Center.
        • bronco31
          • Aug 2009
          • 174
          will double check APS enabled Tray 1 and 2.. and Group cassettes thru web portal.. thanks all
          (so much of our job is tuning)
          • masterchill
            • Jul 2005
            • 100
            I think they have to be the same orientation in order for the fax to use both cassettes.
