6501i - Gray background after 4 or more
  • Samanator
    • Sep 2017
    • 578
    • 23006
    Re: 6501i - Gray background after 4 or more
    Is the registration roller cleaner picking up a lot of toner? Is the developer duct blocked with toner? The ducts gradually become completely blocked with toner.
    My suggestion is to remove the developing unit, and apply your vacuum cleaner nozzle to back end. Remove the fan box and apply your vacuum nozzle to the duct through hole in the back cover. CAREFULLY open up the fan box and vacuum out the ton of toner inside and the filters.
    I'd really like to see samples, but this is my best guess based on ... experience, I guess. =^..^=
    • Samanator
      • Sep 2017
      • 578
      Damn!!! I completely forgot about the developer ducts and the fan box. I knew there was a reason I was putting the vac all over the place.
      Here is the picture sent to the office. The paper is being run letter speed, not R.
        • 23006
        New developing unit ... if the vacuuming doesn't help. =^..^=
        • Samanator
          • Sep 2017
          • 578
          That was it. I was surprised to find we had a dev unit in stock for this machine.
          It was at a female lawyer's office.
