Kyocera Taskalfa 6003i ADF Dead
  • 7star.tech
    • Nov 2015
    • 7
    Dear All,
    Kyocera taskalfa 6003i ADF is dead, the message shows; cannot use the document processor due to failure. The green light which indicates paper feed also does not turn on when a paper is inserted into ADF.
    Thank you for your help in advance!
    • 16416
    Re: Kyocera Taskalfa 6003i ADF Dead
    Have you tried U906?
      • 23009
      What error is stored?
      Maybe C9040 ... lift plate broken?
      Maybe dusty original detection sensor?
      • Samanator
        • Sep 2017
        • 579
        Maybe this might help. Maybe not. But least you can cross this off your list.
        See attached.
          • 23009
          See attached.
          So in short, you build a whole new document processor on a new style frame. Only Kyocera would call this a "modification".
          • Samanator
            • Sep 2017
            • 579
            You're right bk. I got this QA from tech support and noticed the same thing.
            I was having trouble with a 3553ci ADF when I got this QA. If I 906ed the machine, it would work fine for a few weeks then fail. What I did was check the S/N for the ADF to see if it needed any of the modifications talked about in the QA. And sure enough it did. I also checked if the machine was still under warranty. It was but I saw it was going to be a bitch to change all those parts out. I then looked through our lease return machines an found an ADF on a low mileage 2552ci. I work for a small company so it was no big thing to find out if the S/N for the ADFs and other accessories are listed on the paper work. The lease companies we use do not require S/N numbers for accessories. And ADFs, finishers, extra drawers, fax options, ect. are considered accessories. So I swapped the screwed ADF with the lease return ADF and have not looked back. That swapped ADF is still working fine.
            I know its a crappy thing to do, but sometimes I have to do what is going to be the best for my time management.
            But this is also why any used machine we get, I look at with a jaundiced eye. But that is a discussion for another day.
              • 16416
              Yeah, that's crazy.
              • tsbservice
                Field tech
                • 8020
                Ouch, really looks like major PITA.
                  • 23009
                  The modification is about the same as the Matsuri DP (KM-6525) ... the frame that breaks at the left hinge. =^..^=
                  • Samanator
                    • Sep 2017
                    • 579
                    I gotta wonder what the Paranormal Investigation Team of Atlanta (PITA) has to do with this? :-)
                    • tsbservice
                      Field tech
                      • 8020
                      They must (somehow) be involved in making this ludicrous bulletin
                      • JR2ALTA
                        • Feb 2010
                        • 2033
                        I take it were not talking about the 2-sided failure, which requires a cleaning of the CIS reference roller, 906 and/or fw update.
                        • 7star.tech
                          • Nov 2015
                          • 7
                          Thank you all for the kind support. The issue has been solved.
                            • 23009
                            Solved how? Details, please. =^..^=
                            • Samanator
                              • Sep 2017
                              • 579
                              Yes, please.
