Kyocera Half Speed mode Prescribe Command
  • DamianGr
    • Mar 2021
    • 2
    Hi,
    I have an unusual problem.
    I use a Kyocera fs-4200 dn printer for an old mailing device at work.
    The problem is that sometimes pages print too quickly one after another and a paper jam occurs at the mailing machine input.
    As far as I know the printers offer half speed mode. This can be set in the driver. The problem is that our printer works as an LPT printer under DOS without a driver.
    Is there a Prescribe command to set the Half Speed ​​function from DOS or the command line?
  • copier tech
    • 8156
    Re: Kyocera Half Speed mode Prescribe Command
    Originally posted by DamianGr
    Hi,
    How about setting the media to a heavier weight?
    • DamianGr
      • Mar 2021
      • 2
      We used to do this - but it turned out that the drum was very quickly clogged with seized waste toner. Also Helix shaft breaks from toner discharge.
      We use Light and Normal preprinted paper only.
      • dalewb74
        • Feb 2018
        • 1153
        you are in luck. i have a fs2100 and a fs4200. i have the 2100 installed, but not the 4200. but since the print driver is the same. i saw this thread and was curious. looking under printing preferences i found the half speed mode. this is my one new thing learned for the day. as i had never even heard of this before. probably because i have never had a need, but still....
        • dalewb74
          • Feb 2018
          • 1153
          so i see you use it as LPT, but what if you hook it up USB and install the print driver?
