5052 6052 Multi Feed 0511 0512
  • fishleg
    • Mar 2009
    • 426
    I have a customer who is using 75gsm paper and its multi feeding from all trays even tried moving the paper to another copier same thing multi feed jams. Paper looked good just wondering if anyone has any tips for separation issues out the tray? I adjusted the separation pressure on the feed unit but it still multi feeds even with brand new tyres and pressure to the max. Its a 5052ci machine.
    • 22984
    Re: 5052 6052 Multi Feed 0511 0512
    I've had to adjust separation on the KM-xxx2 series, usually increase page separation, by decreasing spring pressure. Is that what you did?
    Possibly related, I have a Toshiba customer that I have increased the page separation, and it doesn't multifeed any more ... but it does misfeed occasionally. But riffling the paper allowed me to pass 150 consecutive. When it gets to that part of the stack, you can hear the rubbing as the rollers slip on the paper surface, leaving scuffs. I hate blaming paper but this paper is very difficult to separate. My customer has been riffling, and not a jam since.
      I've increased/decreased page separation before in an attempt to get the customer's paper to feed. It can be a big pain in the ass to get it just right.
        • 22984
        I've changed increased/decreased page separation before in an attempt to get the customer's paper to feed. It can be a big pain in the ass to get it just right.
        True. I try to make small changes, then if I'm getting a small improvement, maybe go further. On the KM-XXX2 series there are only five increments, default at center. There is always the option of using a different separation spring, but I haven't had to try that yet.
        We've had excellent success on Toshibas, particularly feeding heavy ledger sized labels, by increasing the downward pressure at the pickup roller, and decreasing page separation. It's mostly trial & error ... and a really big box of springs.
        • tsbservice
          Field tech
          • 7948
          Tricky subject paper is. It may looks normal but eye can't analyze paper structure, ingredients, humidity etc. You're either lucky with paper adjustments or not. Anytime make tests with your own known good working paper. As general rule cheap paper is cheap for a number of reasons.
            You're a better man than me, blackcat.
            Is this a design flaw with the machines? What I'm trying to say is the machine rated to feed this type of paper and simply won't do it or is it the paper itself?
              All true. The toughest part about cheap paper is dealing with the customer. I always feel like they think I'm bullshitting them. My policy is that if I bring a good ream of paper and it feeds fine, then they need to get good paper. In the past I've gone to great lengths to get their paper to work. I don't do that anymore.
                • 22984
                This media is way too heavy for the tray pickup mechanism, but telling the customer that they have to use the bypass tray does not mean that they will use the bypass tray.
                You'll get used to endusers ignoring your advice, especially when its inconvenient for them.
                • tsbservice
                  Field tech
                  • 7948
                  In past I have battled with a lot of bad paper feed problems. The point is mid range A3 Toshiba's feed rollers were PMed at 80k and they last about that even with good papers. Then with bad papers they went half life before feed roll goes race slick that was cured usually with exchange of pick with feed roll until second roll goes bad. Nowadays same range machines different make paper feed rollers easily excel this 2-3-4 times up to the point where actually paper feed problems start not with failed/worn out rollers but with sleeping oneways/torque limiter. To have paper multifeed with current machine line for me is always bad-bad paper(presumably machine is not a lemon).
                  • fishleg
                    • Mar 2009
                    • 426
                    So you guys are saying less pressure less multi feed I put more pressure on the separation 🤪.
                    I'd adust the pick up but it's already weak, any weaker don't think it would feed..
                    • tmaged
                      Owner/Service Manager
                      • 1864
                      Less pressure on the spring means more separation force. The further the spring is stretched, it has less separation force.
                      Hope that helps !
                      -Tony
                      www.dtios.com
                      Become a fan on Facebook
                        • 22984
                        I thought that might be the case.
                        Pad separation works opposite of roller separation.
                        With pad separation more spring pressure means more page separation.
                        With roller separation less spring tension means more page separation. Think of it this way: with more spring pressure, the more the separation roller follows the feed, and the less it separates pages.
                        • fishleg
                          • Mar 2009
                          • 426
                          Thank you makes sense. I better go back and try that then I made it stronger 🤣.
