FS 6625 DP
  • brancas
    • Jul 2009
    • 80
    FS 6625 DP
    Good day all. FS 6525 DP paper feed motor is constantly on. Upgraded firmware cleaned all sensors on DP. Replaced said motor and DP Main PWB. Problem still persists. Have two clients with exact issue. No jam codes ,no error codes. Any suggestions?Screenshot_2021-03-03-20-38-05-013_com.adobe.reader.jpg
    • 23007
    Re: FS 6625 DP
    Two machines with this same issue? Is there any chance you've got a pinched wire in the DP somewhere? I've had these DP's torn down to the frame, and there's not much to them. I'd start by re-seating all the connectors, and re-routing the harnesses into the looms.
    • 20gaugeO/U
      • 557
      Re: FS 6625 DP
      Find a 255/305 or a 205c/255c or an FS-C8520/C8525
      Just swap 1 and see if your problem goes away and start troubleshooting. The entire ADF just lifts off once you undo the 2 thumbs screws and connector
