BSOD when printing to Kyocera from Win 10
  • FriendlyTech
    • Jan 2018
    • 30
    Just a quick heads up to all you techs out there.
    Windows 10 KB5000802 (March 2021 update) has been going seriously wrong for some PC owners in the last twelve hours, with several users reporting that the botched update is causing Blue Screen of Death errors when they use printers. To make matters worse, KB5000802 is an automatic security update, which means it has been downloaded […]
    Reports of printer failures include Kyocera, Ricoh, Zebra, and others.
    For those on Windows 10 version 1909, a similar issue is experienced after Windows 10 KB5000808.
    Windows 10 KB5000802 causes win32kfull.sys BSOD
    On Reddit, several IT admins have also confirmed that Windows 10 KB5000802 broke all Kyocera printing for their clients. None of the workarounds helps except removing the cumulative update.
  • darry1322
    • Oct 2010
    • 817
    Re: BSOD when printing to Kyocera from Win 10
    Just now found it here. Came to make sure someone was reporting. Thanks for the heads-up.
    • copiray
      • Feb 2019
      • 29
      I had this problem with two clients today, I managed to fix it by uninstalling today's update 10/03/21
      • tsbservice
        Field tech
        • 8064
        Good to know. Mojorolla already started a thread here:
        Blue Screen of Death - Kyocera printers and new Windows update
        • Leebs14
          • Feb 2014
          • 457
          Yep had a few reports of this today, uninstalled the latest update and all ok again. I've re-created the issue on my laptop and have found if i install the PCL driver it works ok, but the KX or universal driver doesent work.
          • kuby
            • Oct 2007
            • 1414
            Yea need to start a Class Action against MS. Far to many update problems and we can't not choose to install or not install anymore. We are their trouble shooters and testers.
            • qtech
              • Jul 2009
              • 41
              Thought it was a Chinese or Russian hack, but nope.....just Microsoft (again).
              Domestic Terrorism, anyone?
                • 30554
                Blue Screen Fix.pdf
                  • 919
                  Because this was not the MFP fault and a Microsoft caused issue was this repaired as a courtesy or how many of you charged the customers ?
                  • FriendlyTech
                    • Jan 2018
                    • 30
                    I've been sending customers the link and telling them to get with their IT dept to remove the update, stating liability reasons for me not being able to remove the update.
                    • Necrocannibal
                      • May 2008
                      • 212
                      We've just been uninstalling the KX driver and installing the KPDL or PCL driver.
                      Sent from my SM-N986U using Tapatalk
                        That's what I do, what advantage does the KX driver have?
                        • kuby
                          • Oct 2007
                          • 1414
                          The big difference is some options do not install when using the PCL driver on some machines. That is the only difference I see other that one driver for all Kyocera machines.
                          • Necrocannibal
                            • May 2008
                            • 212
                            Just more options, the KPDL and PCL driver are stripped down drivers with no features.
                              • 16526
                              Just got 2 more calls about this problem.
