BSOD when printing to Kyocera from Win 10
    • 16474
    #16
    Re: BSOD when printing to Kyocera from Win 10
    Good Lord.
    I just downloaded the latest windows 10 update on my computer and I got BSOD. Not when I tried to print, but windows wouldn't even load. I had to disconnect every accessory (hard drive, 2nd monitor, ect.) and finally got the computer to boot. This is a fucking major problem.
      • 23010
      #17
      Simply uninstalling windows update kb:5000802 and kb:5000808 fixed my PC this morning. I believe the official Kyocera bulletin appears earlier in this thread. It took me 15minutes ... so it must be easy.
        • 16474
        #18
        I've done that at a couple of customers office where it was a printer problem. On my personal PC, the BSOD had nothing to do with printing. Upon installing the update, Windows 10 would not boot. I read an article that said to unplug all accessories, which I did, then it booted up and I was able to uninstall the updates.
        • JVergin
          Service Tech / IT Rep
          • 216
          #19
          Microsoft did NOT pull the update as reported by Kyocera. They must have lied to Kyocera.
          I had several customers call in this morning who uninstalled the update last week. They were able to successfully print until this morning when Microsoft re-downloaded and re-installed the security update.
          WOW!
            • 23010
            #20
            There's a new Kyocera bulletin that Microsoft Update kb:5000802 & kb:5000808 may remain in the downloads folder, and re-load itself at the first opportunity. I have yet to check this on my PC, but yes, have removed kb:5000802 ... twice.
            1. Open File Explorer. 2. Go to C:\Windows\SoftwareDistribution\Download, and delete all contents.
            There were two folders and 9 update files on my PC.
              • 16474
              #21
              Thanks for that.
              • KYO_OEM
                • Aug 2011
                • 726
                #22
                Windows 10, version 20H2 and Windows Server, version 20H2 | Microsoft Docs
                  • 16474
                  #23
                  Quick Update: I uninstalled the latest updates on my computer and deleted the files as per blackcat's instructions. It didn't work. The next time I restarted my computer the updates installed and got the BSOD again. I'm about to try KYO's solution.
                  • FriendlyTech
                    • Jan 2018
                    • 30
                    #24
                    Pause updates, default is 7 days hopefully Microsoft has it fixed by then.
                    • KYO_OEM
                      • Aug 2011
                      • 726
                      #25
                      Today we installed both patches on diff. systems
                      Here the result
                      • kuby
                        • Oct 2007
                        • 1413
                        #26
                        Billy you need to Pause the updates for about 7 days other wise they will just install again. Maybe in a week MS will fix this, if not just pause it again before the 7 days is up.
                        • KYO_OEM
                          • Aug 2011
                          • 726
                          #27
                          we didn`t uninstall KB5000802 and KB5000808
                          we run additional manual update with KB5001567 + KB5001566
                          and the result you can check in post before
                          • FriendlyTech
                            • Jan 2018
                            • 30
                            #28
                            Can confirm, installed update KB5001567 without removing KB5000802 and issue is gone.
                              • 16474
                              #29
                              This solved the problem for me. I didn't uninstall KB5000802 and KB5000808 but did install KB5001567 + KB5001566 and everything works beautifully. Thanks KYO.
                              • kuby
                                • Oct 2007
                                • 1413
                                #30
                                Also if you run the Windows 20H2 update and restart and then it finds the KB5001567 fix and installs it. Printing OK.
