Kyocera TaskAlfa 5052ci Tray 2 problem
  • Service@PRT
    • Oct 2016
    • 181
    #16
    Re: Kyocera TaskAlfa 5052ci Tray 2 problem
    Did you check the file property rights? for the tray?
    or is the copier set to "use printer settings?
    If i remember correctly it is set to use printer setting.
    Sent from my YAL-L21 using Tapatalk
    Every day of life is a learning process...
    Just make sure you are open in all aspects of comments.
    • tsbservice
      Field tech
      • 8020
      #17
      Did you tried it from different PC? Could be Windows update doing weird things on PC in question.
        • 30294
        #18
        MS will override any driver settings
        Selecting a Paper Source (Microsoft Word)
          from the OP : Normally they are using office and acrobat only
            • 30294
            #20
            Yes dummy MS is office
            Stick to main body dude
            Basic PDF printing tasks, Acrobat, Reader
              • 16416
              #21
              Normally Word is defaulted to "Use Printer Setting" for Default Tray. This setting can be found under Options>Advanced Settings>Print
                • 16416
                #22
                For Adobe Acrobat: File>Properties>Advanced>Paper Source by Page Size
                • tsbservice
                  Field tech
                  • 8020
                  #23
                  Originally posted by Service@PRT
                  Normally they are using office and acrobat only. Oh well i tried different drivers same thing. And yes i discovered today that this problem occurs after windows 10 make update on KB ****802. So someone installed the xps drivers. I remove everything.. even the patch itself. But still a no go for tray 2. Which is really weird.
                  Try those from elevated Command prompt:
                  wusa /uninstall /kb:5000802
                  wusa /uninstall /kb:5000808
                  • Service@PRT
                    • Oct 2016
                    • 181
                    #24
                    Actually.. windows made an update on windows 10 (KB...802) which makes BSOD on kyocera machines and canon middle print is not showing when you send print. At the same time only 1 pc is currently on that office. Im planning to go back and bring 1 laptop with windows 7 OS to try.
                    • Service@PRT
                      • Oct 2016
                      • 181
                      #25
                      I will prepare my windows 7 64 bit laptop for to try.. this laptop is no printer driver installed so everything will be good.
                      Will try to use KX driver which is 6.3.162 version.
