Kyocera Ecosys P2135dn / P2040dn Status Page Shortcut
  • bergerb
    • May 2020
    • 10
    Hi,
    I am trying to print a Status Page via shortcut (Long-Pressing the Go-Button for 3-9 seconds) but it seems like it just does not work on P2135dn/P2040dn..
    Are there any hidden settings to enable that feature?
    I have also seen the usb-stick-prescribe way, but that also involves menu-digging
    Is there maybe something I can put on a usb stick, that automatically gets executed? Or emulate keystrokes or something like that?
    bergerb
    • 30284
    Re: Kyocera Ecosys P2135dn / P2040dn Status Page Shortcut
    PRESCRIBE commands: test page, network status page?
      • 30284
      • bergerb
        • May 2020
        • 10
        Yeah I know about those commands. And also about the manual. But I am looking for a way to print the status page without going through the menu or sending prescribe commands
          • 30284
          On the old kyocera you could send data down throught the web page but I think kyocera removed that feature.
          You can also use the ic-link tool the print status pages
          Also km Net viewer to send data down
          Even if you had the command lines on a USB stick you would still have use the menu key to upload the file.
            • 30284
            Whats the issue with the printer?
            • bergerb
              • May 2020
              • 10
              I know.
              Nothing wrong with the printer. I would like to print a status page with the click of one button.
              Like that:
              But it seems like that feature is missing or disabled on my printer.
                • 30284
                Originally posted by bergerb
                I know.
                Like that:
                That was a really cheap kyocera with no menu thats why
                • bergerb
                  • May 2020
                  • 10
                  Ah hmm ok
                  • ntbann
                    • Jan 2012
                    • 628
                    !R! elog; stat; stat1; page; exit; Save this string in note pad as a .capt file and save it to a jump drive. Plug int machine and print the file.
                    • fishleg
                      • Mar 2009
                      • 426
                      Oooo can you get llu report page this way?
                      So you just turn machine on with usb inserted or will it just run from putting the stick in at any point?
                        • 23009
                        Treat it like printing any PDF from USB. Insert the USB anytime. When the menu becomes visible select the .capt file, and print. It's extraordinarily handy.
                        For a decades I've been using LPR Jar to send PreScribe command files from my laptop, and it works ... but now I do not have to boot up the laptop or connect the network cable. Very convenient. Simply rename the files that I've attached with the .capt file extension. =^..^=
                        • JR2ALTA
                          • Feb 2010
                          • 2033
                          This is good to know. I always thought people were using .prn files and it never worked for me. Probably because it should have been .capt
                          • JR2ALTA
                            • Feb 2010
                            • 2033
                            Can someone explain "saving as a .capt" file? If I have a notepad open it only saves it as .txt
                            • PrintWhisperer
                              • Feb 2018
                              • 472
                              For Notepad, from the File menu choose 'Save as'...when the save window opens, under the filename, change "Save as Type" to 'All Files'.
                              You may now save the file with a .capt extension.
                              Also, if you enable 'View File Extensions' you can see and change the file extension from Windows Explorer Folder window. (Open Windows folder->View menu-> Check 'File Name Extensions' box).
                              "Being ignorant is not so much a shame, as being unwilling to learn" - Benjamin Franklin
