Kyocera P6130cdn- "Cassette 1 Not Loaded" Message
  • Big Flo
    • Jun 2018
    • 15
    In this particular situation, the cassette is loaded. Issue appears to be intermediate as sometimes the machine will detect the cassette and other times it will not.
    One thing I do noticed is that lift motor does lift the paper tray when working properly. When not, it doesn't even make noise.
    I'm not too familiar with the printer, but is this an indication that the lift motor is going bad?
  • KYO_OEM
    • Aug 2011
    • 721
    Re: Kyocera P6130cdn- "Cassette 1 Not Loaded" Message
    Maybe switch size damaged
    remove the cassette and look for paper size switch on the left side.(fig. 13, electrical components 1/ #12/ 302HN44180)
    3 small switches present.
    Press and hold 1 or more and check if motor turns on rear left side.
    • KYO_OEM
      • Aug 2011
      • 721
      additional info
        • 900
        i have had some that would say "set cassette " and KYO is correct the size detect seemed to be the issue.
        • ntbann
          • Jan 2012
          • 628
          Flip the machine on its back. There is a long white flag that drops that get bent out of shape. You will see a stress mark in the plastic. I usually heat it up with a lighter and bend it back if its not broken.
