KM-3252ci black only banding issue crossfeed
    • 23007
    That's about it.
    When this issue occurred it was a little early for the Maintenance Kit A, but one of our techs did it anyway. Since then its had two DV-8350K's and two DK-8350's, and the issue seems to go away for awhile. This is my first time seeing the machine. There is a distinct negative of heavy fill areas 94mm further down the page.
    It's possible that the problem hides in low density halftones as you can see in my 11% fill ANSI B image. The sample I was given has intervals at 37mm, implying primary charge. But the 11% halftone shows intervals at 37mm (primary charge), 45mm (developer spacers), and 94mm (drum). No other color is affected. I can swap in one of the other drums, and the halftone changes density a little, but for the most part the problem remains unchanged. Occasionally just removing a unit and re-inserting clears it up for a dozen or so prints, then the next job has the bands. Cleaning lamps are lighting properly, and drum ground is being made.
    The hotline suggested the HVT, which sorta makes sense (affecting charge and developer bias for a single color). I've got that and another DV-8350K on order.
    Does this look familiar? =^..^=
  • Ropariva
    • 672
      • 23007
      Re: KM-3252ci black only banding issue crossfeed
      It looks similar, doesn't it? =^..^=
      • JR2ALTA
        • Feb 2010
        • 2033
        Yes this looks familiar. I'd ask you to look at your U000 report and tell me if the machine has recognized any of the new black drums/devs SIMS 110,158.
        I suspect not. If you installl a drum or dev and you don't see the machine going into a "adjusting image" for several minutes, it's probably not being recognized and then the process control gets out of whack.
        Believe it or not these boxes really do need to be unplugged when preforming maintenance.
        If my premise is correct; go back with new drum/dev UNPLUG, install and see what happens.
        • Luther
          • May 2006
          • 682
          I would go with the HVT, I had the same issue but it was with all the colors except black same spacing of the image
            • 16390
            That's definitely worth exploring. I've made it a habit to unplug the machine on every service call if there's any disassembly to be done. That way I know when I do a PM that the machine will be unplugged.
              • 23007
              Thanks everyone. I'll let you know how it goes. =^..^=
              • tee
                • Aug 2014
                • 79
                I would make sure that the secondary transfer roller isn't the source of
                the high voltage crossover. It has been the source of problems like this for me.
                Kyocera thinks developer gets into the 2nd roller from bad dv unit. I'm checking
                it first on all 3252ci's.
                • tcook
                  • Apr 2013
                  • 37
                  Our rep was in earlier this week on another issue, but told us about a problem he'd seen a couple of times. The symptom was more light overall image, but the fix was to pull the waste box assembly and reseat it. Apparently the high voltage contacts route through the assembly. Reseating it realigns the springs.
                    • 23007
                    It sounds like this might not be a simple process.
                    I'll add it to my list. =^..^=
                    • JR2ALTA
                      • Feb 2010
                      • 2033
                      Where consumable counts accurate in the U000 report?
                        • 23007
                        No counts are not accurate. I got the story third hand, but a board had been replaced at one point and the total count had been lost. The consumables had been replaced after that event, so those counts are accurate. I believe there was a U021 All Clear at some point.
                        I had considered the possibility that the U930 values were inaccurate, and it was causing inaccurate calibration calculations, but I have been reassured that consumables were changed and reset AFTER.
                        • allan
                          RTFM!!
                          • 5462
                          Looks like 2 things not happening correctly. Leaking charge current and not discharging.
                          If not a component problem on the HVT then a wonky contact somewhere.
                          Whatever
                          • JR2ALTA
                            • Feb 2010
                            • 2033
                            OK, for what it's worth I went down the 930 path as well. After a second PM kit, image PWB and HV PWB I was still stuck. Copies would be good for a few days or weeks.
                            My kyo rep quickly spotted the 110,158 counts were not being reset putting the machine in a process control death spiral.
                            I hope this info and ultimately your solution can help others in the future.
                            • Ropariva
                              • 672
                              Is this a case of the consumables being changed with the power on? Only 930 needs to be reset after a drum change. All other counts are automatic....as long as the machine is powered off.
