TA 3501 Jams a Reg roller I believe 113 Jams Pic included
  • Doug James
    • Jan 2012
    • 935
    [Jamming] TA 3501 Jams a Reg roller I believe 113 Jams Pic included
    Intermittent paper jams. Will work fin then start jamming over and over. Then it may start running copies. I believe the jam is 113 but not sure. (Transport open while copying). I change the transport unit with a known good on still no change. Naturally the copier is about 60 miles away and I have been there twice. Any help would be very appreciated !!!
  • JR2ALTA
    • Feb 2010
    • 2031
    Re: TA 3501 Jams a Reg roller I believe 113 Jams Pic included
    You should really know the code after going there twice and it's so far away. If it is 113, that's an oddly specific code. The machine must feel the door is opening. I'd look at the front and rear latches, items 11 and 17 on PDF page 19.
    But if you see a lot of reddish dust in the machine you could have clutches failing. The drive pack 302L693080
    I'm pretty sure all the clutches in the door are for duplexing.
      • 22999
      Is there any latent image on the belt when it jams? Perhaps your primary transfer belt is stalling? I would have more confidence if you knew what jam code. =^..^=
      • Doug James
        • Jan 2012
        • 935
        I know right, No jam code "Rookie mistake" I had it wrote down and lost the paper. The code is 4101.
        • Doug James
          • Jan 2012
          • 935
          Went back today, Jam code is 4101. I replaced the paper drive pack (And Circuit board attached and motor) also replace the entire conveying door. All off working machines. Did the same thing. Thinking may be a controller board connection of some kind of short. Pretty much gonna sell them a new one. The customer said the bought this machine for $200. THANKS SO MUCH FOR THE HELP !!!!
          • KYO_OEM
            • Aug 2011
            • 710
            At first check if you get J4102 by using cass. 2
            2nd step: check U031/ Regist switch
            3rd step: regist clutch controlling is coming from Feed PWB1 instead of feed pwb2 (changed by you), enter U032 and check "regist" clutch, you must hear a small "click"
            Check clutch itselfs, if it`s rusty or else
            4th step: reconnect FFC/ YC1 from Feed 1 pwb and YC5 from engine pwb
            5th step: check plugs on both sides from FFC, (have seen wrong mounted plugs, because of this we have had oxidations at pwb connectors)
            • Doug James
              • Jan 2012
              • 935
              THANKS SO MUCH !!!
