taskalfa 250ci white vertical stripes
  • charly
    • 65
    occasionally
    white vertical stripes with black print.
    ? anyone has gone?
    kyocera do not learn to color.
    disaster
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1901
    I would try the drum & developer refresh in the adjustment screen. Not really any problems with these units so far.
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
    • charly
      • 65
      I have 3 machines with less than 1000 copies with the same problem
        • 23010
        The developer refresh is most likely to help your issue. Also check the laser slit glasses for toner contamination. =^..^=
        • charly
          • 65
          I already have a possible solution. check out the service Bolletin
