kyocera 2540dw
  • billmcwho
    • Jul 2020
    • 23
    kyocera 2540dw
    getting jams out of the fuser, machine has about 120K. get a 4211 code. pulled the fuser cleaned the sensor (had very little dust) Is there a way to check the sensor without replacing it? The press roller and fuser sleeve look new. thanks for any input Bill
  • Santander
    • May 2009
    • 768
    Re: kyocera 2540dw
    You need to replace the fuser assembly under warranty. The problem is not the sensor, it is the slider material that the fuser film rides on has come unglued and is slowing down the paper causing a timing error. There is a tech bulletin out on this. Many times you can observe smudges on the copy/prints.
    • Luther
      • May 2006
      • 682
      Re: kyocera 2540dw
      Also update the firmware when you replace the fuser, it changes some fuser timing to help with this problem
        • 23010
        Re: kyocera 2540dw
        Kyocera horizontal smudging
        Frequent problem with Ecosys P2040dn/M2040dn
        • Scottb
          • Apr 2013
          • 308
          Re: kyocera 2540dw
          its best to replace the fuser, but often you can give that fuser exit sensor arm spring another wrap and it will get you by for a little while
