Reset total counters in a KM-C4035E ?
  • correo.tony
    • 72
    How to reset the total copier, printer, fax and scanner counters in a KYOCERA KM-C4035E ?
    Someboby knows how to reset a whole ?
  • kyoceradude
    The Great Gazoo
    • Aug 2006
    • 442
    Total counters can not be reset on these machines. Besides its illegal.
    My mission here on Earth is to help all you Dum-Dums!
    • correo.tony
      • 72
      Illegal ?
      And if the owner of the copier asks to do a hard reset your copier to keep track of it when you change your place ?
      • JustManuals
        • Jan 2006
        • 9838
        Resetting the totals' counter is akin to resetting the odometer on a car.
        And since when does a copier owner know anything about a hard reset?
        Paul@justmanuals.com
        • 10871087
          • Jan 2005
          • 1062
          In most places you can put a new counter into a refurbished a machine and sell it as a "refurbished" machine but that is obvoiusly not what this guy is up to.
          Huh?
            • 23009
            How many times do we have to hear this question.
            It's still unethical, and I if did know I certainly wouldn't post it in a public forum. Idiot! =^..^=
            • 10871087
              • Jan 2005
              • 1062
              Idiot!
              That about sums it up.
              • correo.tony
                • 72
                Do not be angry !
                Do not be angry, just look for ways to resolve issues of customers, however we have found a way, it is rescheduling the EPPROM'S of the PRINTED W.BOARD ENGINE ASSY, PRINTED W.BOARD CONTROL ASSY and the PWB IPU U ASSY, it's very easy!
                • vikingmita
                  • Nov 2008
                  • 163
                  -tried with 'the other' service code? (other meaning not 10871087)
                  • correo.tony
                    • 72
                    service code
                    30363036 no rules !
                    other ?
                    currently the only option is to reschedule the epproms !
                    • 10871087
                      • Jan 2005
                      • 1062
                      The real option is to tell them that it can't be easily done and get on with your life. Unless of course your trying to sell a used machine as new???
                      • correo.tony
                        • 72
                        Reset total counters in all Kyocera's copiers & printers
                        pdf attached with material and software needed to reset kyocera EEPROMS if anyone has any doubt as is !
                        Bye!
                        • banginbishop
                          grumpy old git
                          • Oct 2007
                          • 894
                          There is no need for anyone to clock a machines meter reading other than hiding its true age and usage. Meter readings do get reset but only when it has a power surge or boards are genuinely replaced due to fault.
                          Yes i've looked at the link and no its not from kyocera its a third party who don't take responsibility for what you do or what happens - says it all really.
                          Incontinentia Buttocks
                          • jakebear
                            • Oct 2019
                            • 33
                            Re: Reset total counters in all Kyocera's copiers & printers
                            [QUOTE=correo.tony;62937]
                            如果有人有任何疑问,请附上重置京瓷 EEPROMS 所需的材料和软件的 pdf 文件!
                            再见!
                            [/引用]
                            IC-Prog原装编程器可以改计数器吗?
                            • Scott
                              • 196
                              Re: Reset total counters in a KM-C4035E ?
                              When the copier no longer works then he'll be here asking how to revive it.
