Kyocera P2135dn - back of paper toner
  • lama0900
    • May 2021
    • 15
    Hello,
    I've got a Kyocera P2135dn from 2014.
    On the back top of the first page printed there is toner (as you can see in the picture). It's 4.7cm. But as I said, only on the back of the first page.
    If more pages are printed, the toner is gone.
    But then, if you wait 10 minutes and print another page the toner gets on the back of the first printed page again.
    I already cleaned the fuser, got a new drum and another developer.
    The new drum, developer are working well in another FS1370dn, so the problem must be something else.
    Any ideas what's wrong?!
    Thank you
    Martin
    Re: Kyocera P2135dn - back of paper toner
    Originally posted by lama0900
    Hello,
    I've got an Kyocera P2135dn from 2014.
    The new drum, developer are working in another FS1370dn, so the error must be something else.
    Thank you
    Martin
    dirty paper path?
    dirty PTR?
    HAVE YOU TRIED RUNNING ANY sims?
    have you cleaned the machine out?
    so little info
    anytime I go to a machine with QUALITY issues I start by giving it a thorough cleaning
    • lama0900
      • May 2021
      • 15
      So far I cleaned all the paper way.
      It's kinda strange because only first page gets dirty on the back top those 4.7cm.
      Can you explain those two points because i'm not that familiar with the terms PTR and sim (maybe because my native language is German).
      > dirty PTR?
      Thank you for your answer
        > dirty PTR?
        primary transfer roller
        sims = test/adjustment modes
        do you have the service manual?
        • mita
          • Sep 2010
          • 87
          Are you using brand or generic toner? It looks like toner staining on the transfer roller
          • lama0900
            • May 2021
            • 15
            Yes I got the service manual. I didn't try any of those adjustment modes. But I'll have a look into them.
            The maintenance menu doesn't appear because I only printed 20k pages the last 8 years. So I have to figure out first how to get to those modes.
            But thank you for the hint I'll give it a try
              wow no wonder why you are having problems... these machines are meant to be run... you'd be better off with an inkjet machine!
              • lama0900
                • May 2021
                • 15
                Thought 20k pages are not that bad for a laserprinter.
                But that's not the point in this topic.
                Hopefully I'll get it fixed by those adjustments or something like that.
                Other question:
                I'm not using any low budget generic toner, it's some type of "brand" rebuilt toner. Used that the last 8 years as well, no problems until one day.
                Shouldn't the transfer roller contain a little bit of toner? Or does it have to be completely toner free (btw. I didn't touch it with my hands, just rolled it over a piece of paper easily)?
                  Other question:
                  here's the specs for duty cycle for that unit.. it is clearly not being run enough... 20k in years?
                  ECOSYS P2135dn GENERAL Technology: KYOCERA ECOSYS Laser Engine speed: Up to 35 pages per minute in A4 Resolution: Fine 1,200 dpi Duty cycle: Max. 50,000 pages per month Max. average 2,000 pages per month Warm-up time: Approx. 16.5 seconds or less from power on Time to first page: Approx. 8 seconds or less Dimensions (W x D x H): 375 mm x 393 mm x 267 mm
                  if left on there is wear n tear on parts.. mainly fuser parts every time it goes to maintain heat in the fuser the rollers turn... over an 8yr period that's a lot of wear.
                  who sold you this? did you state how many pages projected to print yearly? if YES you got way more machine than you really needed.
                  • lama0900
                    • May 2021
                    • 15
                    Uhm. Yea. Had a inkjet before. Always got dry ink in the jets in the time of school holidays in the summer, 6 to 7 weeks no printing (or other holidays).
                    So I took that laser printer road 8 years ago (was told "max. average of 2000 pages per months" means not minimum). Now I just wanted to fix the problem with the toner of the backside of my first page. Maybe we can go back to that topic, because I really don't want to throw that machine into the trash
                    In the meantime I didn't figure out how to access those adjustments... but still trying with the service manual.
                    • lama0900
                      • May 2021
                      • 15
                      Maybe you gave me the keyword: PTR. I took that one from the FS1370 to the P2135dn and it seems to be working for now
                      It was the only thing I didn't take from the other printer.
                      Hopefully it stays that good.
                      P.S.: The 1370 has run 80k pages in the same time. That transfer roller should be good then with that amount of pages.
                      • Ropariva
                        • 693
                        • Santander
                          • May 2009
                          • 768
                          Getting toner on the backside of the page indicates that the toner in the DV unit and the toner being supplied by the cartridge are incompatible. The reason for getting toner on the backside of the page is that the generic toner [never heard of a "branded rebuilt toner?] is falling off the DV unit contaminating the transfer roller which gets deposited on the backside of the page. Just because you have had good results with a generic toner for a while does not mean that the toner you are getting now is the same, they buy from the cheapest source and the new toner may be totally different causing your problem. Vac out the DV unit, install a Kyo toner, run sim 130 to replenish the dv toner and your problem should go away.
                          • lama0900
                            • May 2021
                            • 15
                            Originally posted by Ropariva
                            Don’t expect any Kyocera to “stay good” running generic toner. It only takes one dodgy cartridge to blow away any savings you might have made.
                            Both right. Took a few pages, then toner got on the backside of my first paper again.
                            So now I've to figure out how to vac out my DV and do the 130 sim after buying new toner. Is it the same as going to maintenance -> developer -> reboot printer, which feeds toner from the cartridge to the dv or is the 130 sim doing something else?
                            The "branded rebuilt toner" is a toner from "kmp" (just google that, if you're interested, but I think it's mainly european market).
                            Thank you both again.
                            • lama0900
                              • May 2021
                              • 15
                              Can I also clean out the DV with compressed air ?
                              I don't have access to a toner vacuumer.
                              Thank you
