Utax 3261i gray band in the back of the sheet
  • avio2
    • Jul 2010
    • 150
    the customer had previously inserted compatible toner
    replace DV UNIT-DK UNIT-FK UNIT (ALL INCRUSTED) - TONER OEM clean roller transfert and all paper conveyng
    U130
    U930
    U410
    work 40k and now again this problem and conveing again whit toner (clean M.C. and reclean covening, guide fuser and roller transfert)
    it occurs mainly in the 1st print at about 3cm from the beginning of the page
    any idea?I have others that have this problem also whit toner oem
    3262 not 3261 , if moderator change 3d subjet , thank's
  • Santander
    • May 2009
    • 768
    Re: Utax 3261i gray band in the back of the sheet
    U130
    U930
    U410
    NEVER have seen this with oem toner. Have seen this a lot with compatible toners. You said that you changed the DV unit and used oem toner, did the customer then install a compatible toner? The only reason you get the gray band on the back side of the page is due to the toner that is currently in the DV unit and the toner being fed from the new cartridge are not the same! This causes the in-compatible toner to drop off the mag roller on to the transfer roller contaminating it that transfers to the back side of the page. Using just OEM toner you would not get this.
      work 40k and now again this problem and convering again
      how long does oem toner last?
      my bet the DA customer put another turd party toner in...CHARGE THEM... clear all turd party toners out of office next time do no more service for them.
      • fishleg
        • Mar 2009
        • 426
        I hope someone else knows exactly never had to do it but I think the event log shows you the last 10 toners inserted and flags up compat toners. I'd print that and be like sorry pal good try but I won't be helping you.
        • avio2
          • Jul 2010
          • 150
          For all
          I know this problem White compatibile toner but in this Copy ,After change dv dk fk use only original Utax toner now
          After change dv ecc this in second cartdrige oem
          • avio2
            • Jul 2010
            • 150
            anyone have this problem?
            another 2 3262i whit same problem whit only 89000 page print and toner is oem!!!!!!azzo:
            • KYO_OEM
              • Aug 2011
              • 721
              you are located in torino/ italy and you wrote "UTAX" toner
              Did you asked UI Innovations/ UTAX italy for further assistance?
              Maybe they can help you.
              Don`t forget to send claim with complete reports to UI.
              • avio2
                • Jul 2010
                • 150
                • KYO_OEM
                  • Aug 2011
                  • 721
                  you wrote that it needs 40K to come back after assembling from new DV, DK + TR.
                  2 other systems with same issue after approx 80K
                  If you use the old units in other system, you get same issue in this system.
                  I don`t know what happens, but something must "destroy" DV Powder.
                  What happens if you use parts from old system in the other system step by step?
                  Don`t forget to store U000/ Maintenance report each time after replacement. (U000 --> stored as *.txt file on USB)
                  Now you can compare the values between before and after
                  Maybe by this way you can find what`s going wrong.
                  Do you get same problem if you switch off U100/ Set AC Auto Adj.?
                  If you switch off, system is working with initial values instead of calculated values
                  (Maybe wrong calculation for needed voltages)
                  With collected U000 data, i think UI will ask UTAX Germany for additional help.
                  • avio2
                    • Jul 2010
                    • 150
                    not now i have only tested old parts step by step in new machine and 3262i are monocmponent not have a dvpowder
                    I will update you how long it took again to print u000, I have too many machines in service to dedicate myself to one afterwards
                    • avio2
                      • Jul 2010
                      • 150
                      another whit only 19k and toner o.e.m.
                      solved?????????????? whit change dv unit
                      but why? need change dv unit whit only 19k , who is the real problem???
