Kyocera M5521cdw Repetitive print Defect
  • Jaws
    • Oct 2007
    • 236
    Have a repetitive image defect at about 76mm, book says 75.3mm is drum. Anyhow, looking at drum and I cant see anything wrong with it.
    So, I ran a drum refresh several times and the DEV-CLN several times. Nothing changed, any insight would be appreciated.
    See attachment
    • 23010
    Re: Kyocera M5521cdw Repetitive print Defect
    If you notice, there is a line each of CMY at equal intervals apart. I suspect that you've got scratches on CMY drums ... yes all of them. Maybe somebody "cleaned" the machine for you? =^..^=
    • copier tech
      • 8195
      See attachment
      As the lines are in all colours I would suspect the transfer belt is causing the issue.
      The customer can't access the drums to scratch them but they can gain access to part of the transfer belt so take that out & inspect it.
      • tsbservice
        Field tech
        • 8041
        All 4 drums. It would be expensive I guess. Swap cyan drum with yellow and see if cyan marks become yellow.
        • fishleg
          • Mar 2009
          • 426
          Belt or someone has took the drums out and they weren't gentle putting them back in.
