M3145idn with IB-51 wireless card
  • kuby
    • Oct 2007
    • 1400
    Question will the M3145idn with a added IB-51 work with Pin Point scan. I can not seem to Pin Point scan to connect using the wireless card. I have set machines up with Pin Point that have a wireless internal installed and they work great but never a IB-51.
    I am thinking this is just a print server, but others said it does not say that anywhere.
    Anyone ever done this? Thanks
  • kuby
    • Oct 2007
    • 1400
    Re: M3145idn with IB-51 wireless card
    OK found out from Kyocera that the IB-51 is not Hypas compatible.
    They were going to put the printer where there is not ethernet port of the wall. Been trying to get them to have us install a drop there.
      From what I have read on this forum, a cheap wireless router will outperform almost any of these wireless cards.
      • tmaged
        Owner/Service Manager
        • Oct 2008
        • 1880
        Just about any wireless bridge is what you want. The IB-51 would only be needed if it were going to access two networks simultaneously, IMO.
        Hope that helps !
        -Tony
        www.dtios.com
        Become a fan on Facebook
        • kuby
          • Oct 2007
          • 1400
          Found out from Kyocera that the IB-36 will work with Hypas. That is what they decided to do.
          • Scottb
            • Apr 2013
            • 306
            does this machine not have wireless already onboard
            • kuby
              • Oct 2007
              • 1400
              No the machine is a idn, no wireless card.
              • Samanator
                • Sep 2017
                • 578
                I have encountered way too many problems with the IB-50 and IB-51.
                When I have to do wireless on a machine without wireless built in, I use a TP-Link AC750 Wireless Portable Nano Travel Router. Cheap and flexible and dependable. Just a suggestion.
