Utax 3508ci error c2700
  • johnny32
    • Oct 2007
    • 102
    Hi all
    have a utax 3508ci throwing an error code c2700 first thing every morning.
    Once machine turned off and back on works all day either no issue.
    Machine has 100k on it and has also had a new tr8560 installed.
    Any help greatly appreciated
  • dalewb74
    • Feb 2018
    • 1153
    care to share what you have done so far to try to fix it?
    • johnny32
      • Oct 2007
      • 102
      Have replaced the transfer and reseated all the connectors
      • ntbann
        • Jan 2012
        • 628
        I would check the connector on the front of the machine where the transfer belt plugs in. They get bent real easy.
        • nathicana
          • Aug 2008
          • 335
          The belt release motor code C2700.
          The belt release motor is located in the main drive unit. The good news is for the Kyocera 4 series machines you can now order just the belt release motor instead of replacing the entire main drive unit. 303TB94010 PARTS DC MOTOR ASSY C
          For your UTAX machine I'm not certain which generation it is, you may need the main drive unit. It's the one that drives the developing and drum sections.
