Kyocera P4040dn fuser problem.
  • Ihar
    • Nov 2020
    • 17
    I have the Kyocera ECOSYS P4040dn (A3 paper format). And I'm trying to find some fuser roller for its. Fuser assembled is FK-7300, but it costs to much (like new printer). Anybody know which fuser roller come there? (it has d=30mm).
  • rapo_tech
    • Feb 2019
    • 114
    • Ihar
      • Nov 2020
      • 17
      Re: Kyocera P4040dn fuser problem.
      Originally posted by rapo_tech
      Which A3 printer cost around 500€ ?
      Looks like fair price for fuser unit.
      Anyway it is 500k unit. So not only fusing roller is worn out. Bushings and bearings and all the components will be failing in future.
      Its analog (Kyocera P4140dn) costs near 800€. The fuser unit FK-7300 for Kyocera P4040dn costs near 400€.
      The fuser unit on this printer has printed only 130k pages (not 500k), and the fuser roller surface is damaged (teflon coating has worn off).
      • avio2
        • Jul 2010
        • 150
        from the photo I found on the web the upper fuser looks similar to that of the 3010
        • Ihar
          • Nov 2020
          • 17
          If you mean the Kyocera Taskalfa 3010, it has a different fuser roller (it dosen't look like this).
          The fuser roller from P4040 looks like the fuser roller from Kyocera FS-4100 (but the FS-4100 has A4 paper format).
          The fuser roller from P4040dn:
          • Gift
            • Mar 2011
            • 2459
            I'm not much fa miliar with kyo but I know for some models it makes more sense to buy a complete MK kit wich includes more PM parts and isn't much more pricey compared to buying just the FK/DK.. stuff.
            • Ihar
              • Nov 2020
              • 17
              The MK-7300 service kit for P4040dn costs more than the new printer P4040dn.
              Does anybody know - what is the deameter for the transfer roller in the Kyocera KM-8030/6030 TASKalfa 820 620?
              • nathicana
                • Aug 2008
                • 335
                Here's a place that advertises the FK-7300 for a better price
                Genuine New Fuser Unit For Kyocera Ecosys P4040dn Fk-7300 - Buy Fk-7300,Fuser Unit For Kyocera Ecosys P4040dn,Fuser Unit Product on Alibaba.com
                  • 23009
                  I feel like I should know this, since I worked on quite a lot of the Harriers, but I do not, and Kyocera did not include a repetitive defect chart in the earlier manuals, which includes CS-8030 and CS-820. If my imagination is accurate, I am imagining that transfer roller at ~25mm diameter.
                  The fuser roller is probably ~60mm diameter. =^..^=
