Kyocera 2 and 3 Series Separation rollers.
  • bdesire
    • Oct 2012
    • 62
  • craigster
    • Apr 2016
    • 201
    Re: Kyocera 2 and 3 Series Separation rollers.
    303LL07191 new gray roller
      • 23006
      If you don't have that, I use Konica Minolta rollers A00J 5636 00. They'll consistently last 300K, and are not difficult to press off/on to the old hubs. =^..^=
      • JR2ALTA
        • Feb 2010
        • 2033
        True for feed rollers but these gents are discussing the ADF sep roller.
          • 23006
          Oops! Thanks for the correction. =^..^=
          • Samanator
            • Sep 2017
            • 578
            Did they really change the roller surface or just the color? The yellow ones seen to work well but they looked crappy after a bit of use. If the gray ones are really a change, then I may do well to get a few for some of my higher volume ADFs.
            Now there may be a subject, high volumes on ADFs that are attached to mid to low volume machines.
            As for what blackcat alluded to, I often wondered about that (putting a Konica Minolta roller; P/N A00J 5636 00; on the shaft of a Kyocera separation feed roller). However, I never worked at a place where Konica Minolta and Kyocera were sold at the same time so I couldn't try it.
            Thanks blackcat!
              • 23006
              Thanks blackcat!
              The Kyocera black rollers can last less than 100K depending on the model. But most of the Kyocera rollers are exactly the same size as those KM rollers. And the ribbed pickup roller works nicely also. I made up a roller press ... where's the thread ... here:
              Zeus Feed Rollers
              Enjoy! =^..^=
