Do you recommend Kyocera copiers to sell?
    • 8146
    #16
    Re: Do you recommend Kyocera copiers to sell?
    Originally posted by Scott
    I have talked to a dealer that is mainly KM. He was attending a Kyocera launch. I asked him why he was at the event and his reply was that the Konica's just weren't holding up. So he was looking at adding Kyocera
    ... perfect time to consider Toshiba Tec. Toshiba's eBridge Next line, now in its second generation, is rock solid, well featured, easy to work on and very economical to maintain with consumables often exceeding factory spec.
    • Gab
      • Aug 2015
      • 669
      #17
      Yes! much much better machines.
      Ithink indipendent is better but it depents of the country and the way you work. you have more freedom what todo.
      Perhaps you have to consiter to import fromChina perhaps some parts ,not toner .Toner better to be genuin for these machines.
      • Gab
        • Aug 2015
        • 669
        #18
        Originally posted by JR2ALTA
        Absolutely. But I think unless you have lots of salesmen and buying power you'd start off with their Copystar line. Same product and resources but geared towards the smaller dealer.
        You can also use olivetti line
        • Samanator
          • Sep 2017
          • 575
          #19
          Who makes olivetti mfps?
          • Robinh
            • 114
            #20
            Thanks for all the great comments. I will always value the opinions of technicians over anyone else. ;-)
            • Robinh
              • 114
              #21
              i used to work on Olivetti typewriters.
              Lexicon 94C
