KM-6030 Blur 3 inches from trail edge
  • JDD
    • 28
    I have a KM-6030 when running in letter with the 11 inch side as the lead edge. I get a front to rear frame blur/ Stretched-out Font (like there fatter than the rest of page 1/4 inch wide and it lands just under 3 inches from trail edge of paper any ideas? -Also it does it on Status Reports and print jobs-
  • Jimbo1
    • Mar 2008
    • 845
    Sounds like transfer or drum stalling. Can you stop it and see the stretch on the drum image????????
    "Some days you get the bear, some days the bear gets you."
    Cdr. William Riker
      • 23008
      "No..."
      I had an observant customer point this out to me.
      He says: "Can I show you something?"
      Me: "Sure. What's up?"
      He pulls out the transport drawer and points to the white separation wire where it connects to the bed.
      "You see that wire? Yesterday it wasn't connected to anything. It was just hanging there."
      Me: "You mean the spade connector was pulled off?"
      Customer: "No..." then he reaches over and gently pulls the disconnected wire from the back of the spade connector. "...it's just not connected to anything."
      I thanked him profusely for saving me a huge amount of time to diagnose what looks like a perfectly good connection. Also J62 & J63 jams. =^..^=
      • JDD
        • 28
        That is good hands on info!
        I have the info and will look at what the posts reffered to. Jimbo I havent stalled yet
        • charly
          • 65
          if a blurred vertical strip on the right side of the page and see more about gray matter of adjusting the sim U053 Setting: setting separate RESIST MOTOR Registration motor speed adjustment
          I have had the problem on all my machines
          • JDD
            • 28
            Reply to sim change
            Thanks Charly I will try that, any special # to set it at or is it different for every machine
            • charly
              • 65
              no, I will adjust until it disappears the strip blurred
              • JDD
                • 28
                charly right on the money Thanks
