Kyocera Taskalfa 6002i
  • brunot
    • May 2012
    • 148
    [Error Code] Kyocera Taskalfa 6002i
    Hi,
    The machine (Kyocera Taskalfa 6002i) shows error F460 at startup.
    Has anyone faced this problem?
    • 22952
    Re: Kyocera Taskalfa 6002i
    Interpret this however you can:
    Component: CreateBox (Memory Tx). Category: ImageProcess. Unrecoverable Error.
    Turn power Off/On.
    1) Power Off/On, if re-occurs 2) HDD Initial in system menu (System Menu, Adjustment/Maintenance, System Initialization). Power Off/On, if re-occurs 3) Reformat HDD (Status, 10871087, 024, Start, Execute, Start). Power Off/On, if re-occurs 4) Repl HDD.
    The basic steps here for all print data errors is to update the firmware. Then try to determine the source of the errors.
    For example: today I had an attorney that was emailed a PDF scan of a legal document. When sent to print, page 14 always pulls a CF248. Mostly as an experiment, I suggested that the enduser use the Microsoft PDF converter to re-save as a new document. The resulting document prints fine. Other known sources of print data errors is printing directly from web based applications and web pages with links, and all prints from Macs.
    The hardest part is usually trying to figure out which of the 50 users, 50 PC's, and thousands of possible print jobs could be corrupt. I was just plain lucky today to have an alert enduser that identified the corrupt document. =^..^=
    • PrintWhisperer
      • Feb 2018
      • 454
      Unplug the machine from the network and boot to see if there is corrupt print job being sent, then like BC says, find the print job sitting in some queue and delete it.
      Reflash firmware and update all print drivers.
      CF46x is Main PWB process error of print data from corrupt job or bad Main PWB. HDD is indicated for F47x-F49x.
      "Being ignorant is not so much a shame, as being unwilling to learn" - Benjamin Franklin
      • brunot
        • May 2012
        • 148
        Turn power Off/On.
        Hi,
        I've performed the steps (destruction of stored JOBS in HDD) and now the machine is working properly.
        Thank you, much appreciated.
          • 22952
          Congratulations on your success. =^..^=
