Kyocera 2554 machine failure
  • Brandon
    • Jun 2019
    • 72
    Good morning
    we currently have a Kyocera 2554 that keeps giving machine failure C7301 we have replaced the complete toner hopper assembly and a week later the error is back , anything else you guys are aware of that could be causing this issue , any advice is welcome
  • kuby
    • Oct 2007
    • 1400
    Re: Kyocera 2554 machine failure
    Check wiring and make sure that connections are secure. Firmware up to date. Image drive PWB. Engine PWB.
      • 23007
      +1
      The manual also refers to feed image PWB. =^..^=
      • PrintWhisperer
        • Feb 2018
        • 471
        +2 on Firmware and not over KFS unless you read the release notes (so FUBAR)
        U135 -> Check Toner motor operation (do not drive for too long) and check for (k) sensor value change.
        HOP_PLS_BK is YC11 pin5 of...Image Drive PWB (sry BC)
        "Being ignorant is not so much a shame, as being unwilling to learn" - Benjamin Franklin
        • Brandon
          • Jun 2019
          • 72
          Thank you that was our next option
          • Brandon
            • Jun 2019
            • 72
            tried all suggestions but still no luck .............
            • nathicana
              • Aug 2008
              • 333
              Any solution? Same symptom at a little over 4,000 prints, C7301
              • PrintWhisperer
                • Feb 2018
                • 471
                This one is getting funky. If you are authorized, have your manager call the Kyo rep because that hop_pls_bk signal needs checking while running U135 along with some other signals like Hopper full.
