taskalfa 5002
  • Gab
    • Aug 2015
    • 656
    taskalfa 5002
    MAchine suddenly prints double image. Like those caused from deteriated heat roller. After 2-3 hour it printed ok. Any idea why is this happened?
  • Ropariva
    • 629
    If one of my techs rang me with this I’d hang up. They know they need to do more of the basics before I’ll talk to them about copy quality issues. Usually they will go back to the basics and in the process will solve the issue themselves.
    If you are a senior tech, what would you want your junior to tell you about the machine, the problem and what they have done to narrow down the possibilities.
    • lyspeedboat
      • Nov 2024
      • 1
      The double printing was likely caused by the fuser or heat roller not reaching the correct temperature initially, possibly due to temperature fluctuations, residue, or wear. After a few hours, it stabilized, allowing it to print normally. If it happens again, inspect the fuser or consider replacement.
      phrazle
        • 22930
        A sample might be helpful. Also measure the distance between the repetitions to confirm that it is the fuser.
