CS 300ci - Black Lines at edges
  • cmessin1
    • Sep 2019
    • 2
    Hi,
    I have a used CS 300ci that I had picked up used about a year ago. It does not get a ton of use. It was printing very nicely when I got it. It has probably printed about 2000 pages (almost all B&W) since I received it.
    It is admittedly a little overdue for its first Maintenance Kit (Black) based on page counts.
    Recently I started getting lines just at the edges of the paper. I am attaching a picture. The arrow I drew denotes the direction of print.
    Wondering if anyone knows if there is something I can clean to improve this as a short term solution or if I need to move forward now with the maintenance kit.
    SwiftScan Sep 30, 2021 10.14 AM.pdf
    Thanks.
    • 22997
    Re: CS 300ci - Black Lines at edges
    The black developing unit would probably resolve this issue. Here's the thing though. This machine is obsolete, meaning that you won't be able to get parts much longer. You may not be able to get the black developing unit.
    If you're a gambling man, you might want to buy that Maintenance Kit A while it can still be bought.
    If you're not a gambling man, you might want to spend your money on another machine.
    It's really up to you. =^..^=
    • PrintWhisperer
      • Feb 2018
      • 465
      ... This machine is obsolete, ...
      BC is dead on and here is the main issue. That is basically gen 2 Kyo color after the *ugh* Voyager series. It did NOT have a system to STOP driving color while in BW use as later gens did.
      This means that the Color Drums and more importantly DV's are always driven and would overcharge unused colors.
      They all wear equally with the BW count, there is no sep. color counter on these.
      They suffered from frequent HVT failures
      The transfer belt material was changed and early machines, esp. 250/300 would have trouble keeping TX belt clean.
      Probably one of the worst 'wholly Kyo' color MFP's ever....
      "Being ignorant is not so much a shame, as being unwilling to learn" - Benjamin Franklin
      • cmessin1
        • Sep 2019
        • 2
        Thanks much for the insight, moving forward with Maintenance A.
        • qtech
          • Jul 2009
          • 41
          Pull the Drums, at least one of the drums will have this pattern of foreign matter on it. Carefully clean that drum, or drums, and you will be good for the near term. I seem to recall something about the Transfer Belt causing this, especially in low volume (or stored) units. Replace Transfer Belt and keep a drum or two on hand; as mentioned, this is an old model so an upgrade would be best.
          Chris
